Does wheel offset effect alignment?
cuttheduck
1,267
Mar 28, 2004
detroit, Michigan
Some Relative info
Car- Talon Tsi
Suspension- prokits and illuminas
Wheels- 7.5 wide, 45 offset
Tires- 225/40/18
I seem to be having slight rubbing problems on the rear of my car from a new tire/rim setup. This rubbing is on the inside, not the fender. I put some tape on there and after a long drive I wasn't able to tell that it was rubbing but it may be.
I was going to get an alignment tommorrow and want to know, If I add 5mm spacers to the rear later will this throw off my alignment?
I could never get a positive answer on this and heard both sides. Thanks
No, it will not effect your alignment. There maybe some alignment mechanic here or there that will tell you othewise but we've discussed this here a couple of times and we all seem to agree on this one. Wheel size and offset do not effect your alignment.
  • Wanted 6 bolt NT water pipe
    • chrisman287
