Does the 21 spline t-case work with a 4bolt rear?
dsm93turbo
41
Jan 3, 2007
Alger, Ohio
Ive been getting some parts to get the awd system back put togeather. I have a 4bolt rear driveshaft and a 22 spline t-case. Will these work? The guy said the rear end is out of a 5spd car. Is there any way to tell this? i know i have to get a 22spline tranny. Im just wanting to make sure everything will work togeather before its in the car. Where can i get the rear subframe mount that goes to the rear of the diff with 2 bolts and then bolts back to the car body.
The way to tell if it's from an auto or a manual is the gear ratio. A 1G DSM manual has a 3.545 ratio (39 tooth ring gear/11 tooth pinion gear) and an auto has a 3.307 ratio (43 tooth ring gear/13 tooth pinion gear)
All the gear ratio info for the trans, xfer case, and rear diff you'd ever want can be found here Tranny gear ratios for DSMs
Rick - '91 GSX :dsm:
  • Wanted 6 bolt NT water pipe
    • chrisman287
