difference in bodies?
disanto
Aug 25, 2008
Kansas City, Missouri
Ok so i was searching around and was wondering, whats all the difference between the 2g's for the bodywise? Other then headlights/taillights and badging? Will an eclipse hood or fender for instance bolt right onto a talon?
Yes everything is inter changeable between the two cars.
However in some cases when you change one thing you have to change others to get them to fit right. For example if you’re going to run 97-99 head lights you also have to have the 97-99 front bumper. The hood I think is the same for all 2gs I’m not sure though.
Ah thanks a ton clears quite a few things up for me, for in the future for when and if i start modifying the body. +rep to both of you.
The only thing that is not a direct bolt on is the rear bumper, you have to modify the rear bumper bracket and there are plenty of places on here that show you how to do so
  • Wanted 6 bolt NT water pipe
    • chrisman287
