Difference between turbo & n/t piston rings?
drewbuddy
113
6
Jun 19, 2011
edmonton, AB, Canada
Is there a difference between turbo and non-turbo rings? and how can you tell, if there is a differenc that is. My rings were ordered through napa, and wondering how to double check if they are right
According to rockauto.com, they are the same, but according to mitsubishi asa they are a different part number. It is possible that they are the same thing with just a different part number from the factory. If you are using an aftermarket ring than i assume that they are the same part number.
k thanks, they are alltrom rings and they got them in and then sent them back cause they weren't sure so makes me wonder. when i looked it up they were same part number as well.
Anybody else with input is welcomed advice
  • Wanted 6 bolt NT water pipe
    • chrisman287
