giovanniv
- 384
- 0
- Aug 8, 2008
normal,
Illinois
Alright well I ran into a slight problem. Basically I did not have my engine at the 1st cylinder TDC when I took off my old cams and now I already installed my new delta cams without my engine being at tdc. Will I have problems with my marks on my cams and the crank not being together at TDC? What about the cam angle sensor since i have a 1g 7 bolt and I have the hall type cas?
... I have never had a problem turning the crank while having the the cams set at TDC... This is a joke.. There is no problems with moving all that stuff.. Just be carefull and if feel resistance dont slam it.. Just set the timing with the cams in..
