Denso 660cc install problem
anumeric
66
May 27, 2003
I have a problem installing these injectors into my 2g with a 6 bolt. The clip that holds the injectors onto the rail doesn't seem to fit right with my injectors at all. If i line up the clip with the injector i have to pull some of injector out of the fuel rail...195500-0610 is the part number...thanks
i just didn't use the clips, however my motor runs like crap on the 660s even with dsmlink because my motor had sputtering to start with...the injectors made them worse
