delta 272s now valve guides are toast..
Blaze4G63
191
May 30, 2008
NW, Washington
so i bought and installed deltas hks 272 about 2 months ago and now it seems that my valve guides are toast :notgood:....is this normal never reved over 7k and im pretty sure its vavle guides because it blows blue smoke on start up and not underload or sitting at a light any help?? engine might have 30k on the rebuild
I've had Delta 272s and am currently running Delta 280s and never had an issue. Plenty of people are running the Delta cams with no problems.
I would better guess that it's your valve stem seals.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
