Sold Delete
punk3rz
213
95
Jun 1, 2012
Tennessee
1998 Mitsubishi Eclipse GSX
5 speed
115k miles
Clean title
ZERO RUST
Located in Kingsport, TN
$10,000 FIRM
This is a feeler post because I’m considering buying a second home and don’t drive it that often.
My price is firm, I would not take a penny less so don’t waste my time.
This isn’t a hacked up, budget built car by an inexperienced mechanic so don’t bother wasting my time and I won’t waste yours.
I bought almost all of the stuff done to the car new, with receipts for everything that would be included.
The car is currently tuned on 93 pump gas running 30psi on a conservative tune.
The car is tuned, drivable, and reliable.
All aftermarket parts on this car minus the transmission have probably 2k miles or less on them.
Here’s a list of mods off the top of my head:
ENGINE:
6 BOLT LONGBLOCK
OEM MLS HEADGASKET
HKS 272 CAMSHAFTS
CROWER SPRINGS & Ti RETAINERS
KIGGLY HLA
ARP HEAD STUDS
ARP EXHAUST MANIFOLD STUDS
FF OFH
TURBO/EXHAUST:
FP CAST RACE MANIFOLD
DEI MANIFOLD BLANKET
HOLSET HX35 BY JUSMX141
BEP TURBINE HOUSING
PR EXTERNAL MVS O2 HOUSING
TIAL 38mm WASTEGATE
3” BUMPER EXIT EXHAUST
INTAKE:
JMF RACE SMIM
S90 70mm THROTTLE BODY
ISC/FIAV DELETE
FP INTAKE PIPE
VRSF FMIC
TIAL BOV
FUEL:
FIC 2150cc FUEL INJECTORS
FIC FUEL RAIL
AEROMOTIVE A1000 AFPR
FUELLAB FUEL FILTER
-6an FUEL LINES FROM PUMP TO RAIL
WALBRO 450
IGNITION:
NGK WIRES
JMF PLUG COVER
COOLING:
KOYO RADIATOR
MISHIMOTO RACE FAN
GAMBLE GARAGE COOLANT OVERFLOW
MISC:
POWDER COATED -6an VALVE COVER
GAMBLE GARAGE CATCH CAN
PROTHANE MOTOR MOUNTS
JAYS ALTERNATOR RELOCATION
GATES RACING BLUE TIMING BELT
-12AN DRAIN OIL PAN SETUP
BALANCE SHAFT DELETE
EGR DELETE
EMMISIONS DELETE
CRUISE DELETE
AC DELETE
DRIVETRAIN:
SHEP STAGE 3 TRANS (STAMPED)
COMP STAGE 3 CLUTCH
ENKEI RPF1 17X8.5
HANKOOK VENTU EVO V2
MEGAN COILOVERS
REDLINE FLUIDS
INTERIOR/EXTERIOR:
INNOVATIVE MTX-L WIDEBAND
GREDDY OIL PRESSURE
GREDDY BOOST
B&M SHORT THROW SHIFTER
OEM (RARE) LEATHER WEIGHTED SHIFT KNOB
OPTIMA YELLOW TOP RELOCATED TO TRUNK
ENGINE MANAGEMENT:
ECMLINK V3 FULL (tuned by Kenny Kline)
SPEED DENSITY
MAC BCS
FUEL PRESSURE SENSOR
EXTRAS(not installed but included):
EVO 8 BREMBO BRAKES
GM ETHANOL SENSOR
ECMTUNING ETHANOL HARNESS
LSD REAR DIFF W/ AXLES
SOLID DIFF BUSHINGS
MAINTENANCE(last 2-3k miles):
BR7ES PLUGS
NGK WIRES
MLS HEAD GASKET
TIMING BELT
ACCESSORY BELTS
RADIATOR HOSES
RADIATOR CAP
COOLANT
HEATER HOSES
VACUUM LINES
FUEL LINE
FUEL FILTER
AIR FILTER
AN LINES
WATER PUMP
REDLINE DIFF FLUID
REDLINE TCASE FLUID
REDLINE TRANS FLUID
VR1 OIL
OEM OIL FILTER
BRAKE FLUID (new cap)
CLUTCH FLUID (new cap)
MISC BUSHINGS
If you’re seriously interested in the car and you have funds available, send me a message or email me at [email protected] and I will get back with you ASAP.
The ONLY trades I would consider are RUST FREE Galant VR4 or Mighty Max with good OEM paint.
Thanks
