Dashboard swap question
ElementDO
80
Jul 20, 2006
Hagerstown, Maryland
I got a dashboard out of a 97 Eclipse Non-Turbo. Will the wiring in the dash match up to my 95 GST or should I swap the old wiring harness out with the new dash? I tried searching....
The factory gauges are different. I did this exact swap on my car and I chose to change the harnesses as well. All you have to do is take the air ducts off and the wiring harness is screwed in at various points underneath them. The two harnesses will mount in the same spots, and it only takes about 10 minutes to change them. I kept the n/t harness I took off laid out to the side in the same direction as it was when it was mounted just to make sure I was putting the turbo harness on the right way.
Once you get it appart it is pretty straight forward. Yes, swap the wiring. Otherwise I can imgaine it will be all sorts of f'ed up. LOL
