Dash gauges question
KaLo
51
Feb 12, 2006
Leamington,
Hey guys
I was wondering if its possible to replace the in dash gauges with aftermarket gauges
RPM/KMH/engin temp/oil temp/fuel those ones...ive seen people put RPM gauges in front
of the other one...but i want to put the gauges in the dash bot just in front...anyway is this possible?
If you hook everything up properly ( No easy task to install aftermarket Speedo's - IMO)
But just fabricate a base plate teh same exact ahpe as the cluster, and mount it in there with the aftermarket gauges in there, carbon fiber would look really clean.
The cluster is the assembly that all of your stock gauges are mounted in ( there is a little plastic wall, rigth behind your steering wheel.
My friend autoX's when he stripped his entire interior. and it was difficult to make our own Speedo, you can choose to buy one if you choose, I am sure someone sells them.
Exactly. I remember seeing a thread about this recently and there is a picture with the exact setup exiletalon has explained, carbon fiber as well.
