crower cams stage 3
stay tuned
30
Oct 7, 2003
hey guys i just got a great deal on the crower stage 3 cams for my 93 gsx can you give me some feedback on it and what kind of hp it makes , i got them for 200 bucks and it was used for 4 months
mark
looks like i came out the worst........that is real depressing, seeing that the cams i got were the worse ones...wow thats real depressing....
Unless you are running that exact same parts and your car just happens to be tuned exactly the same and you just so happend that your engine was built to the exact same spec, take those results with a several LARGE grains of salt.
In fact, I don't recommend that anyone really do more than glance at that test and forget it. There were a number of problems with that test. If you are running a pretty large turbo, have the appropriate mods to support it, and can tune you will do fine with those cams.
AMS stated all the problems they were having. They were dropping boost near the redline, which would make a high lift/high duration cam not show to work as well because the boost isn't there to make it work its hardest. Get some cam gears ( yes even HKS cams need cam gears, unless your a BPU only kinda person, and tuning is for losers ) and get them running for your car. They are definitely better than stock, horsepower wise.
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
