Cooling a t 25
HOTcrew
Apr 29, 2004
Starkville, Mississippi
I need help with where to tap the coolant lines for a t 25 on a 420a. I wanted to know if i should tap the water lpipe above the manifold or if i need to do it from somewhere else. If so where should I tap the lines?
90% of the people i see tap a line from the coolant line running up top the exhaust manifold, they weld on another pipe were the pipping beggings off the rubber hose, to the turbo. My turbo is liquid and oil cooled but i dont have the coolant hooked up, 90% of the people i see with 420a cars & turbo's that can be cooled with coolant dont even bother, im sure it will help the turbo but it wont kill it if you dont have it attached. I have a T3 and it runs fine, a guy who is 420a pro told me the turbo would be fine and ive had no problems wit it cause the oil cools it.
