Coolant Temp. Sensors - Where to Buy?
DSMWillyb
350
May 19, 2002
Windsor, Colorado
I was driving home today and my CEL came on. Code: 21 - Coolant temperature sensor and I knew exactly what it was. But I am not sure of the correct names of them.
Here are the pictures:
Is this the Water temperature switch??
Here is the connector that was attached to the two wires in the above picture, and attaches to the upper circle...
I'm pretty sure that this is the coolant temp. sensor
I don't need the sensor itself, but the portion that attaches to the wiring harness (connector). If you know the proper name of these two pieces let me know (Or if you have the part number that would be great).
Also if there is a place online that I can check prices please let me know
TIA..
Will.
