Converting between CFM and lbs/min
doug -
sorry, it's a little too easy for us engineer types to get way out there instead of keeping things simple!
Anyway, if it was me, and I had no previous experience to guide me, and there wasn't anyone to ask about it, what I would do is:
1. figure out the max engine air flow as per my article, using:
a. max rpm I'd expect to spin the engine to
b. max boost I ever planned to run
c. my best guess at the engine's VE
d. my best guess at the IC outlet temp (if an IC is present)
The key there is to be honest about those things. If I was planning on a pump gas street car, I would not want a compressor that would be good to 30 psi. I'd probably say my max boost was 20-23 psi maybe, if I thought I'd be using water injection or something, or maybe 17 psi if I wasn't going to do any of that. Whatever, honesty is key.
2. Once I had that air flow I'd convert it to acfm at my local conditions. For a given mass air flow you'll need more cfm capability up in the mountains than you will at sea level.
3. Then I'd find a compressor where that cfm is about... I dunno... 80%? 90%? of the max that compressor could do. If I needed a 400 cfm compressor, I'd look for a compressor that was rated up to 450-500 cfm. Or if I was looking at a compressor map I'd want all the curves to start falling off at 450-500 cfm or so.
That should give you a turbo where you are getting the maximum use out of the whole map, not just part of it, and it should keep you out of any part throttle surge problems you might get with something that is way oversized.
To me, the key to all that is good honest estimates of you want it to do, and what you engine really needs. It's too easy to fall into the bigger is better trap. We all do that with cams, heads, everything, but sometimes what makes for a good race car doesn't make a good street car. In the same way that 250deg cam is great at the track, you may be a lot happier with a 220deg cam on the street. Being honest about the turbo size you need might also make for a better street car. But hey, if you are going to be running 25 psi, by all means get something that can do it efficiently!
4. On the turbine side, there is so little info out there (at least for GN turbos) that I would have to consult a vendor to get their recommendations on what would match my chosen compressor. If I had a performance curve for the turbine, I could pick one out on my own. It's a bit complicated though, so I won't go into it here. Once I got one though, I could, if I had the desire to optimize it, start measuring backpressure at the turbine inlet. That would tell me if it was undersized or not. If I was making 20 psi boost, and saw 50 psi backpressure, then I could say whoa! I need a bigger turbine! And if I saw 20 psi backpressure, I could figure I might be a little oversized, and might get a little faster spooling with something smaller, and it shouldn't hurt my performance too bad. Sad to say, with the limited info out there, recommendations and experimentation is the best way I know to pick out a hot side to match the cold side.
John
a. since our engine redlines at 7500, I was thinking of using that. Is that too high, or is it OK? I do tend to push it to redline at the track, and just shy of that on the street occasionally.
b. max boost EVER, or typically? I would guess 20 PSI max on pump, but 25 or so with race gas. I probably would only run race gas 2-3 times a year, though, so would that factor into the decision?
c. Any ideas from the DSM gods on how to figure this one?
d. See c. :D But seriously, anybody know how/where to get this number? I wouldn't even know a ballpark figure to use. Who among us has an intake air temp gauge probe mounted after their IC and could share some insight?
I do appreciate the help, everybody, thanks!
wow..ive been reading this stuff for about 2 hours straight...i feel like im back in school. im really trying to comprehend all this because Turbo's are not cheap and i want to get the right one for my applications. i just started a thread last night asking someone to explain what A/R and trims and everything means. This thread and a few others have been very helpful in discussing VE and CFM and flowrates etc. Now the problem is using that information because it seems most vendors do not provide flow rates and such except generic things like "600cfm" which doesnt really help by itself. Thanks for all the info!
I would suggest going to turbonetics for garret compressor wheel maps, and a stealth site I'll try to link to at the end of the post that has maps for mitsu wheels, and calculators to figure out outlet temps, manifold temps, pressure ratios, density ratios, etc. All I can say is JDEstill is hitting nails on the head all over this forum. I have been playing with these maps and numbers for a couple weeks now and everything he is posting can be "measured" using these formulas.
Here is that link, there are many branches to it, be sure to explore everyone of them. Its easy to get lost, but there is a TON of info.
http://www.stealth316.com/2-air-fuel-flow.htm
http://www.stealth316.com/2-adiabat1.htm
http://www.stealth316.com/2-converters.htm
And the money maker http://www.stealth316.com/2-3s-compflowmaps.htm
HOme page is http://www.stealth316.com/0-frames.htm
Good stuff. Get a bag of chips and a 6 pack and have at it :D
