Controling Boost With E-manage
TT_NS
203
Dec 2, 2003
Can E-manage Controle boost? If so how? If not wut would be the best way to control boost while using E-manage? Thanks.
Emanage doesn't control boost. Are you confusing it with the Greddy E01 Boost controller?
best way to control boost would be well.... a boost controller. You can opt for a 40$ manual, 300$ profec b, or a 500$ profec e01
best way would be E-01. You can use it as an emanage programmer and monitor. Also, you can use the E-01 pressure sensor to run fuel and timing maps off of MAP instead of TPS.
True you can tune with Map instead of TPS, But for the $1K+ it would cost for this setup is not really worth it when you can shell out a couple hundred more for SAFM.
