Confused on wires for oil filter housing
phillabaum03
849
3
Nov 28, 2005
sharpsville, Pennsylvania
Theres 2 connections on the oil filter housing and im not sure if its the 2 wires that go along with the alternator wires..I need a picture of how the wires connect to the oil filter housing..thanks
I am pretty certain that the Alternator and oil filter housing (wires) are bunched in the same harness... 1 wire is originally light blue on mine... I had to extend it because it broke off before I got the car.
The other wire I had is white, both of mine were disconnected, I had to fix them, don't laugh. I hope you appreciate the pics I went outside in 20 degree weather, laid down on my ice covered driveway to get them for you... Hope this helps.
dvb
Damn man..Thanks so much..That is exactly what i needed...Weather just had to be so cold today...
You got it bro, with my limited knowledge, I am glad I can help someone out even if it's with just a picture!
dvb
I did the 6 bolt swap and went to start it and the timing belt came off the cam gears..So i sent it somewhere to get fixed..ha
