Compression Question
K_Hill
417
76
Mar 25, 2005
Polk, Tennessee
Ok I just rebuilt me motor and put a new port and polished head with crower cam gears, manly valves and springs, and COMP ZEDEX RACING CAMS GRIND NUMBER XE259HR-111 INTAKE LIFT 411. EXHAUST 395 LIFT.. I done a compression test and 1 and 2 have 140 - 160 psi and 3 and 4 only have 30 - 60 psi. What could be my problem here?? Could it be a timing issue?? I need help very badly!!! I can't figure it out. :mad:
Sounds like it is your timing. Those cams may need to be degreed in.
check and make sure all the plugs are plugged in. my power transistor plug wasn't in and that was the reason my compression was lookin like shit. easy miss. i know it was for me.
What would a power transistor have to do with compression???? Compression is a measure of the air being compressed by the piston / rings against the head. This is totally mechanical...
i was just stating what happen to mine. my compression went from 115-50-125-120 to 177-180-180-182 just plugging that plug in. and that was 3 days in between each other. just stated what happen to mine. thats all.
jeremy
jeremy
Maybe your battery was low on your first test or you did it on a cold engine? Then the second time you had more of a charge or the engine temps were up to where they should be? Either way unplugging that transistor won't change compression number ... it's physically impossible.
