Compression/Leak down test results.
Badarse97
34
Aug 3, 2009
pomfret center, Connecticut
Compression test:
175,165,160,150
No time to put oil in the 4th because i had to go. :( but i assume it would of went up though.
Leak down:
first and second=no leaks.
third was something like 5%
4th was around 10-12%
so you guys think my rings are ready to poop out?
Could be carbon deposits. I had my #2 cylinder reading 12% leakage, did an extensive Sea foam treatment, and brought it back up to 6% leakage. I had to put seafoam thru the FP regulator vacuum port to get it to into the #1 & #2 cylinder, then for the other cylinders thru the BOV vacuum port.
Oh ok cool. ill try it out.
I forgot how that stuff works. just put the hose from the FP or BOV Vac into the can while its running?
I usually dump that Seafoam into a spray bottle, and spray it in so the motor doesn't die. Though I think you could "probably" let the motor suck it in on its own, that one I never tried before.
I thought using seafoam could sometimes find leaks you didn't know existed and make things worse instead of better ?
it can if your engine has 150,000 miles and has never been cleaned. All the carbon on the valves might be keeping those leaks plugged. When you clean that carbon out you opened up a whole new problem. As long as you maintain your engine that shouldn't happen.
