j_eclipse96
- 175
- 0
- Oct 26, 2004
Laramie,
Wyoming
Hi, been having the stuttering problem that has been popular apparently. I checked my TPS and replaced my plugs already, and cleaned my throttle body. Now I checked the coil pack (used guide from 2gnt.com). I couldn't get a reading from the primary coil check, but the secondary check (testing the towers) read about 16 ohms, about 3 ohms above normal according to the guide. I checked my wires as well, and the contacts look clean (thats the only way I could think of checking the wires). So should I replace the coil pack, or just try swapping my plug wires first? Thanks.
