Co2 sprayer
Bud92gsx
Welcome Wagon
23,182
429
Jan 16, 2008
Wisconsin, Wisconsin
I was spaying that duster stuff today cleaning electronics..It's basically liquid co2.
The cryo2 are stupid pricey for the kit..But a 10 lb bottle on ebay is 55 bux.Then get the nossles and IC sprayer,lines..I think I could peice together a kit for under 200 bux.
Any suggestions..Thoughts?
I allready have The 2 nozzles for the windsheild washer setup spraying the ic...
I did just buy a supra smic..You think I should stay with the washer pump spraying the IC.Rather than co2..
Is spraying co2 such a bad idea?
Why not just buy a water injection kit? About the same price and will do a lot more cooling that the CO2 or windshield wiper water on the intercooler.
:hmm: True that..
But this will be for track/dyno only..
Yes I could do water/meth..
Hook up a, fuel pump to it instead of,a washer fluid pump. It push water through much harder causing more atomization. :thumbup: but your best gains will be from water/meth
My Buddie had the same idea once but including a programmable controller .. I forget what all was involved, but I do remember after doing research a co2 sprayer of any sort it useless
Well I'm thinking flashable ecu..With the ability to add water/meth /IC sprayer...
On the supra sidemount..It looks like my winter build is shaping up allready...And I think this 14b is gonna be hurting when spring comes.
Won't work. A fuel pump uses fuel for lubrication and electrical insulation. Putting water through one will quickly kill it.
I'm actually developing a CO2 kit now that lets you set a strict temperature output. So your can will see the same intake temperatures all the time. It's not bad actually. But for racing only. It's not something that will last on a DD. You'll be filling your tanks as much as you fill your gas, depending on your temperature settings.
