clutch slips in higher gears only
i can theorize:
Basically while the numerically lower gears do make more torque, this isnt seen at the engine rotating assembly because this is generate after the gearbox. BUT the higher numerical gear indicate a higher speed, which creates more load on the engine which IS seen at the rotating assembly. This is also why you tend to make more boost and sooner in the higher gears.
Also, if you're still in the "saving up" stage.....you might (if it hasn't gone on for long) be able to adjust the clutch pedal to get a touch more life out of the clutch until you get all the funds together.
It all depends on where it was adjusted to the last time the clutch was changed, but it could give you a couple of extra weeks worth of operation if you're easy on it.
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
