Clutch Problem 98GST
EclipseSH21
926
4
Aug 17, 2004
East Lyme, Connecticut
K, on my GST, i am having a problem where the clutch easy to push down and engage, but its hard to get the car into gear, it doesnt just click in. There is no grinding at all, but you really need to pull to get the car in gear. Also, the clutch pedal is slow to come up. Ideas on what this could be? Am I going to need a new clutch setup or is it just the throwout bearing/shift fork??
Could be your throwout bearing, you could have air in the line (Bleed the system first!), you could need to rebuild your master, slave cylinder or both. good luck with it!
Looks like it's just gonna need an entire clutch job. Oh well, i figured thats what it would need anyway. Thanks though, just making sure it wasn't something weird. :cool:
  • Wanted 6 bolt NT water pipe
    • chrisman287
