Clutch noise
ggsx
Feb 10, 2022
denver, Colorado
Hello, so I'm having a weird issue that doesn't really make sense to me.
I'm having a noise from the clutch i believe but it only happens when I put the transmission into gear with the clutch pedal pressed in at a stop and it is also hard to shift into gear. I think it's the throw out bearing not disengauging the clutch all the way, But the part that confuses me is if I release the pedal like a half inch to an inch the noise stops and I can shift into gears fine.it doesn't make sense to me because if the clutch wasn't disengaging all the way and dragging. Why would releasing some of the pressure disengage it?
Edit: i should also note that before anyone says the pedal just needs to be adjusted it was working fine til I drove it yesterday. Although I have since adjusted t he pedal to make it driveable I can still hear the noise slightly with clutch in and putting it into gear. The hard shifting into gear is basically gone though
