Cleaning 1Ga font turn lenses?
1320B4U
45
Aug 29, 2002
Is cleaning the 90-91 front lenses(turn signals) the same procedure as making your own clear corners? Heating them in the oven to get them apart, then sealing them with silicone?
Thanks, Isaiah
Are the inside of your lenses dirty? If so, I would think that you would have to do that procedure, but before you do that, you might want to try the yellow headlight fix in the tech articles section (if that's the problem). I think there is also a fix for mini chips on a headlight (if this is the problem).
  • Wanted 6 bolt NT water pipe
    • chrisman287
