Check out these coilovers
ryanx99GS
247
Sep 26, 2005
St Louis, Missouri
SpeedyRacer Coilovers?
eBay Motors: Mitsubishi Eclipse 95-99 96 97 98 GS GST GSX Coilover (item 170230130173 end time Jun-23-08 15:33:06 PDT)
- $490 shipped.
- MONO inverted tube shock with dustboot, non adjustable dampening
- Aluminum Upper Pillow Mount
- Front Spring Rate: 200mm - 8kgf/mm, 8in - 448ib/in
- Rear Spring Rate: 200mm - 6 kgf/mm, 8in - 336ib/in
eBay Motors: Mitsubishi Eclipse DSM 2nd G 95-99 Coilover Suspension (item 170229158988 end time Jun-20-08 13:03:54 PDT)
- $730 shipped.
- MONO inverted tube shock with dustboot, 16 ways of adjustable dampening
- 1-5: Suggested for Track Use
- 6-11: Suggested for mountain/aggressive use
- 12-16: Suggested for common street use
Anyone ever heard of them/have these?
If you're going to go as far coilovers buy a name brand that is proven. Suspension is important and a set of coilover isn't necessary better than strut/shock combo. For the first set of coilover I doubt it will be as good as the AGX/Eibach or the Tokico/Eibach.
I would give the first set a try if your not into autoX or road racing cause people never use all those adjustments mainly cause they don't know how to correctly. If I woudl have seen this I would have bought them but I already have a set of dropzones installed.
Hmmm....
"Great deep sound with removable silencer"
Ha. I saw that too and laughed a bit.
Anyways, I wouldn't buy those coil overs. You just don't know what quality you are getting. (just look at the quality of the advertisement.... LOL removable silencer)
Although if someone on this board does have those coil overs then please chime in.
Tom
The sell exhaust and obviously someone dropped the ball with the listing but doesn't make the kit any less quality. There a bunch of better options that cost a lot more money. I do not think piecing a kit together will be better no matter how much people knock it.
Eh, just wanted to see if anyone has ever heard of them or have them currently. I had NEX's that I picked up from a friend for cheap but sold them. My engine is currently getting rebuilt and im just searching around for some suspension combos. Just thought Id' see some feedback about these
