Cheapest place to get fuel injectors
SnoopySLR
1,157
4
Nov 14, 2002
Highland, Michigan
I'm looking for the best deal on a set of 550-650cc injectors for my 2gNT. Accel or RC would be cool, but I'm open to other brands as long as they have good reviews.
Second question, should I replace my OEM Fuel Rail? I'm trying not to spend a fortune here cause I just got new seats and a MS2 system... but I know I have to upgrade my fuel if I wanna get the most out of my MS and not have to re-tune it several times.
The cheapest Ive seen RC 650s for was on ebay at around $260 shipped. If you want 550s EVO injectors are the way to go as they actually flow quite a bit higher, around 580. You will not need to replace your fuel rail until you go quite a bit higher.
evo8 560cc injectors are your best bet and I have a set for sale for cheap.
Is that really your car in the avatar? I want more pics!
Evo injectors should run $100 or so and probably the cheapest. I got mine for $85 shipped.
Whatever injectors you plan on buying, make sure you can easily get the correct o-rings and bushings to make them fit right, This may sound dumb but injector seals are very important and regular 'home depot' o-rings wont cut it. For example, if you get FIC injectors, about the only place to get replacement seals is from FIC and there $25 just for o-rings and spacers,WTF.....
try evolutionm.net for the evo injectors, evo guys tend to have them for sale alot
  • Wanted 6 bolt NT water pipe
    • chrisman287
