changeaxle seal how much fluid loss?
solo92s10
149
Oct 16, 2005
Elizabethtown, Pennsylvania
I just got done putting in a new clutch and flywheel, while there i put in new axle shaft seals and i think i pushed the one in to far and am not getting a seal. Im going to pull the axle again and put in a new seal. How much fluid am i going to loose from pulling the axle? I have a extra qt of royal purple syncromax which is what i am ussing, will i need more than one qt?
You should have enough with an extra quart of fluid. I have seen it where you only loose a cup and also where you loose a quart but what you can do is when you jack up your car only do the side you are going to work on. This will tilt the tranny and should help to reduce your fluid loss. Hope this helps you Travis
