Cas??
Boxer132c
77
Dec 3, 2004
Fairview Heights, Illinois
I had to ship off my cam angle sensor but I also had to ship off the crank sensor but I dont know where the crank sensor is...I have a 1st gen 4g63..can some one send me a pic of it or describe where it is???
1G's (90-94) Have only one sensor which is the Cam Angle Sensor. The Computer uses it as a Crank and Cam sensor.
2G's (95-99) Have two seperate sensors.
Cam sensor which is located at the end of the head(tranny side) and a Crank sensor which is located behind the crank shaft sprocket wgich is behind the timing belt.
So to answer your Question you already took off the crank sensor if you have a 1G 4g63
like your saying.
