ECMlink Car runs like poop, log file inside
GST with PSI
DSM Wiseman
2,758
1,666
Jul 27, 2005
San Diego, California
So I have been struggling to get my Galant VR4 to run well since I reinstalled the motor after rebuilding it. GST with PSI's build & restoration of 1813 | Galant VR-4 > General VR4 Discussions | GalantVR-4.org Mitsubishi Galant VR4 Forum Problems I am currently having:
- Car overheats, even with both cooling fans running. In short, I do not believe this is because of the cooling system, nor the fans. I think this is related to how crappy the engine is running. Cooling Issue (updated). Need help, pics inside. | Galant VR-4 > Technical Discussions | GalantVR-4.org Mitsubishi Galant VR4 Forum
- Car will not start again after it gets hot. It cranks, but wont event try to fire.
-Car has a high idle, and will not go into closed loop. It runs pretty smooth, but the throttle response is garbage.
I found out today after logging a bit with my DSMlink that my coolant temp sensor is not working at all. I reads a constant 9 degrees Fahrenheit. This would explain one of the reasons why the car won't go into closed loop. Additionally, the timing seems to be way to advanced at idle. I'm just getting into what expected values should be, and what to look for while logging. If I'm missing something blatantly obvious, It's because all this is pretty new to me. I'm sure there are lots of problems glaring at me, I'm just too much of a DSMlink noob to realize it :ohdamn:. Could some of you guys with more ECMink experience here take a look at this log and tell me what you see?
***At 105.5 seconds on the log I grounded the timing connector using the link feature. The car subsequently started running like crap, and eventually died. It wouldn't restart afterwards. So, just as a heads up, that's why there is the durastic change in the log at that time.
Car info:
Everything is pretty much stock...
Stock motor
Stock 450cc injectors
2G MAF (I switched this on Link)
Walbro 255 with fuel pressure set @ 37 PSI
Thanks!
First things first, adjust your TPS so your at 0% at idle and at proper voltage.
Tuning 101 - tuning with the car off - YouTube
Secondly disable simulate idle switch from TPS. If you have a 1st gen you have a idle switch in the TB and do not need to simulate one.
Pulled this from galantvr4.org
Basic DSMLink Tuning Guide
(This guide is exactly what the title implies, a basic guide to tuning. It is not intended to teach you, or tell you, everything needed to tune a DSM. Research will be required to fully understand the terms, values, and procedures below. With that said, the people involved with any and all aspects of this guide are NOT responsible for ANY damage done to your car.)
Written and edited by: Shane2GSX and NickNorth11
Before You Start:
• Verify that Base Timing is correct
• Verify that Base Fuel Pressure is correct (1g manual = 37 psi; 1g auto = 43.5;
• 2g = 43.5 psi)
• Verify that there are no boost leaks
• Ensure all other components are working correctly
• Swap plug wires to account for different CAS (97-99)
• Approximation of desired values: (Some of these must be obtained manually and some via DSMLink. Others are simply values to monitor and keep within given parameters.)
A/F Ratio (closed loop) 14.7
(open loop) 11
AirFlow (compare to specific turbo output)
AirFlowPerRev (at idle)
(1g) M/T = .27 +/- 10% (.24 - .30)
A/T (neutral) = same as M/T
(drive) = .31 +/- 10% (.28 - .34)
(2g) .31 +/- 10% (.28 - .34)
CoolTmp (1g) x>189°, sufficient operating temp. to tune
(2g) x>179°, sufficient operating temp. to tune
if: x<206°, full timing
206°<x<224°, -1°
x>224°, -2°
IdleSw (car off / ecu on) 1
IntTemp 34°<x<84
ISCPosition 30 (at idle)
LearnedIdleAdj 140 (at idle)
LTFT Lo x&#8594;0, (0+/- 5)
LTFT Mid x&#8594;o, (0+/- 5)
Front02 cycles around .5 (.05-.95)
RawThrotPos 32
ThrotPos if: idle, 0
WOT, 100
TPSvolts .63 (when RawThrotPos = 32)
Setting Initial Parameters:
1. Setup wideband operation within dsmlink.
2. If needed, change BoostEst to your respective engine size. (2.0L, 2.3L)
3. Set the A/F Ratio prefs for your injectors.
4. If base timing is off, adjust timing sliders across the board to compensate. (if 3, add 2)
5. If needed, cancel out any CEL’s due to already known causes. (such as rear O2)
6. For safety and if desired, set Knock CEL to 3 degrees knock.
7. Set global and dead time parameters according to specifications for injectors.
8. Set desired values to be logged.
Closed Loop Tuning (Cruise/Idle):
1. Setup DSMLink to Log the following (if available):
a. TPS
b. STFT
c. LTFT Lo
d. LTFT Mid (2G) or LTFT Hi (1G)
e. MAFRaw
f. Wideband
g. Boost sensor (GM 3 bar, AEM, etc.)
2. Turn on vehicle and let warm properly.
3. Drive normally, cruising for at least 10 minutes - Do not go WOT
4. Let car idle for 5 minute before shutting it off - Stop logging
5. Choose your method of closed loop tuning by first determining if AirflowPerRev is at an acceptable value at idle. If AirflowPerRev is not acceptable, evaluate whether adjusting fuel trims with airflow sliders will improve the idle AirFlowPerRev value. If airflow adjustments will improve AirFlowPerRev, begin tuning using step 4 of Method 1. If AirflowPerRev is acceptable, proceed to step 4 of Method 2.
Method 1 – Airflow Metering:
1. Turn on vehicle and let warm properly.
2. Begin logging. Drive normally, cruising for at least 10 minutes - Do not go WOT
3. Let car idle for 5 minute before shutting it off - Stop logging
4. Compare LTFT for idle (Lo) and cruise (Mid) operations – Strive to get as close to 0% as possible. (1Gs are limited to a minimum of -4.7% fuel trim and should therefore strive to attain a slightly positive fuel trim; 0 - +5%)
5. If either is greater than 5% from 0%, proceed to step 6. If not, and your happy with your %, you may stop.
6. If LTFT Lo is negative, decrease the 50 Hz slider in the amount of that value. (i.e. If LTFT Lo is -10%, decrease the 50 Hz slider from 0% to -10%).
7. If LTFT Mid is positive, increase the 150 Hz slider in the amount of that value. (i.e. If LTFT Mid is 10%, increase the 150 Hz slider from 0% to 10%).
Or: (From method 2) If LTFT Lo is greater than LTFT Mid, increase dead time. If LTFT Lo is less then LTFT Mid, decrease dead time.
8. If adjustments are made, return to step 1.
Method 2 – Fuel Delivery:
6. If LTFT Lo is greater than LTFT Mid, increase dead time. If LTFT Lo is less then LTFT Mid, decrease dead time. (If dead time is adjusted, adjust the A/F props settings for the new value).
7. If LTFT Lo and LTFT Mid are equal but non-zero, adjust global setting.
Open Loop Tuning (WOT) Fuel & Timing:
1. Choose a desired fuel/octane level.
2. Choose a desired boost level that you want to run. Dial your boost in at a lower boost setting to begin with, depending on turbo size, probably no more than 1 bar.
(An alternate to the previous method is to start at your target boost level with conservative settings, i.e. low timing and rich mixture. Make a few pulls before tuning to ensure safe operation before continuing with this method).
3. Choose a proper A/F Ratio to shoot for in the entire RPM range – Some common A/F ratios are 10:1, 10.5:1, 11:1, 11.3:1, 11.5:1. The proper A/F ratio will depend on your specific vehicle and its setup. While there are too many variables to list when determining a proper A/FR, some of the common ones are fuel octane, intercooler efficiency, and turbo size. In most cases, on a properly running DSM, on pump gas with an efficient intercooler, an 11:1 A/FR is a common and safe ratio to make good power with.
4. Ensure that all values you want to log are set. (The following are recommended).
a. Wideband
b. Boost sensor
c. EGT
5. After warming the car properly (warm car, drive at cruise for 10 min., idle for 5 min.), data log a 3rd gear pull from 2000 RPM to redline. Keep a very close eye on Knock, A/FR, and EGT’s for anything that might spell trouble.
• If you see ANY Knock, increase fuel sliders. If A/FR is already richer than your target, reduce timing by a degree instead of increasing fuel.
• If no Knock is present and your A/FR is leaner than your target, increase fuel to desired level. If A/FR is richer than your target, and you’re at your target boost PSI, decrease fuel.
6. Allow car to cool down between runs. (Number of runs between cool down periods will be dependant on intercooler efficiency and boost level, among other things. Not doing this will result in inconsistent results).
7. Continue logging runs in this manner until you reach your target A/FR with no Knock.
8. Once you reach your target A/FR with no knock, raise boost by 5 PSI or less. Repeat steps 5 through 7 until you reach your target boost PSI.
9. Once you’ve reached your target boost PSI and desired A/FR with no knock, increase timing by one degree and log another 3rd gear pull from 2000 RPM to redline. Again, keep a close eye on Knock, A/FR, and EGT’s.
10. Repeat step 8 until you see one degree of knock retard. At that point, reduce timing by one degree. (Aim for high teens to low 20s for timing advance. Higher is better.)
11. Finally, do a full run from 1st through 4th gear, watching Knock, A/FR, EGT’s, and boost. Watch knock especially closely. Ensure you run the car very hard. If you see any Knock, you may need to reduce timing. If you see that your A/FR’s are off, you may need to adjust your fuel.
^He's not even to the point that he needs to start idle tuning or worry about TPS values. The car can't even idle properly, so that needs to be addressed first.
Please read and let us know if you've done everything on this list:
http://www.dsmtuners.com/forums/ecm...efore-you-ask-ecmlink-dsmlink-log-advice.html
I'd also take a look at this threads as well:
http://www.dsmtuners.com/forums/ecmlink-tuning-help/444831-list-values-log.html
http://www.dsmtuners.com/forums/ecmlink-tuning-help/443307-helpful-links.html
It's probably running like crap since your front o2 sensor is not cycling. I'm also not sure if your coolant sensor is working properly, since it's reading 8-9&#176;. This can also cause the car to not idle/run properly at all.
