car not running right, live data info:
newtypedsm
91
May 2, 2004
Panama City, Florida
my car is starting up strangely but not all the time, it cranks, then idles rough between 200 and 400 rpm for a minute or two, then adjusts itself correctly. at wot open throttle it backfires and falls on its face and while cruising i can feel it 'jerk' every once in a while. i thought it was from the accumulated rust in my tank, so i put in a new tank, pump, strainer, filter, and had the injectors professionally cleaned (to which they said the injectors didnt really need cleaning). so i changed out the MAF, but to no avail. i hooked up a live data scanner and watched everything at idle and here is what i could remember...
B1S1=0.9v
tps=1.1%
IAT= 130*
engine coolant=210*
RPM=900-950
i didnt notice the map reading and i cant remember what the air flow reading was. at the time i did this, the car was idling smoothly. i could press the accel pedal and tps % would change, o2 voltage would drop, and air flow number would change. this has got me stumped. im thinking i either have: two bad fuel pumps, a bad FPR, or a bad ecu at this point.
and by the way, according to my VDO water temp gauge, im constantly running 220* and it gets up there within a couple minutes of driving after the car has sat all night and radiator fan comes on almost immediately when car is cranked
im still stumped on this one. ive swapped out map sensor and changed the crank sensor again. im now thinking i have a bad ecu, but i took it out and apart and found no blown caps, or burn marks. its gradually getting worse, to the point at where im getting roughly 12mpg. the backfiring is getting more aggressive when i let off the accelerator and even doing it for a split second when i depress the clutch. i pulled my plugs and they appear to be burning excellently with a tanish/grayish color. and in the mornings or after sitting for some time, if i start it and press the accel. pedal it will choke out and rpms drop until it stalls, or i let off the pedal completely.
