car not gettin spark
fasteclipse1992
786
Jan 17, 2003
joplin, Missouri
ok i took my 1.8 out put a 2.0 turbo engine in hooked up all the wires connectors ect. hooked ecu up cranked over but not gettin a spark to any cylinders i got a nother power tr unit from salvage yard, put it in, could it be my ecu caps? i tried the 1.8 ecu also still no spark. soo close to gettin it done.
check your crank and cam sensor that will make you not get spark. YOu can also get a new coil pack. First of all before you drive it get all new suspension because that 1.8 engines a little diff than the 2.0
ok ty for the response, a lil late tho. i got it running a long time ago. was a bad ecu problem.
far as the suspension, what diff would it make? i can see it be a problem if the engines were alot different in weight but there pretty close to the same weight. the stance of it sits the same and the ride is still smooth and straight. no alingment problems. but i do still have the front springs, struts and all the steering componets from the turbo talon. i may change it all because the talon had a lower stance than my eclipse. like 1-2" drop.
  • Wanted 6 bolt NT water pipe
    • chrisman287
