Car idles very rough
lurchwithgst
Jan 10, 2008
walnut grove, California
I actually have 2 things that I need help with.
1. I just got my 1997 gst spyder and the head gasket was blown. I had the head gasket replaced and the head was sent in and pressure tested and resurfaced. Now the car runs real rough at idle when its in gear and semi rough when its it park, cause its automatic. It seems like it wants to die at stop signs. Every once in a while it will idle a little better but then go right back to idleing rough. Any tips?
2. My transmission is automatic and I want to do a swap for a 5 speed manual. I have got a list of some parts that I will need from other forums, but I was wonderingif someone had a complete list oof what would be requierd to do the swap.
Any tips or help is greatly appriciated. Thank you!
If the head gasket was blown, then there might be more wrong then just that. It could have possibly overheated and did more damage. Due a compression and leakdown test. Check plugs and wires. Take one out at a time and see if it gets any worse.
I have done a compression and leakdown test. it had a full diagnostic at a mechanic shop, the compression was between 145 and 155 in different cylinders. I also have changed all four plugs with champion iridium plugs and all four wires. The car runs fine, except when at idle.
Rough idles, depending on the severity of it can be anything from vacuum leak to a bad cylinder or valve. you said you checked compression, did you do a leak down test as well? Also, i didn't look at your cars mods, but it is it "hunting" for idle by going up and down, or is it just rough and low?
How does the car accel? Does it feel sluggish at all? If thats your first dsm and you just now got it running it would probably be hard to tell, but it might be a boost leak.
Also is your Blow off Valve recirculated? All the hoses connected, to the intake and bov? That would cause rough idle/stalling.
it is hunting a little bit when in drive. It seems to go up and down between 800 and 1000 rpms but at times it gets ruff!! I think the shop did a leakd down test, but i will check with them. Thank you for the help.
I do not have any mods on the car at all yet. This is not my first dsm but it is my first dsm with a turbo, my other eclipse was a 96 gs. It picks up pretty good, but when it is cold it does hesitate a little, that might be normal though.? But idk. Thank you all for the help so far
That is exactly what it does, it idles fine when it is cold then as it warms up it starts to hunt for an idle theh almost die, I have been so busy lately and have not been able to even open the garage to even look at the car. I will check the egr valve tomorrow after work. Thank you very much. I want to get the entire engine running completely smooth and sound before I start buying upgrades.
