Car dies after clutching, in neutral...?
1991TSiGFORCE
52
Nov 11, 2007
Brooklyn Park, Minnesota
Hey guys, i drive a 91 talon tsi awd, I need some help on what this issue may be. My car is in neutral, idles fine, but when i step on clutch, rpm drops and car dies. Usually its a throttle body leak for me but this time its not. Any thoughts on what it may be?
Not if it happens in neutral, the car wouldn't attempt to modify the fuel pressure. Most likely, whats happening, is you are pushing the pedal in, and the clutch is being pushed onto the flywheel for some reason, thus stalling the car. Possibly jammed linkage, master/slave cylinders dying out. A whole host of things.
It's a 91. Meaning its a 6-bolt. No crank sensor to get chewed apart. Most likely your flywheel/clutch is on the way out.
.... 6 bolts can have the same symptoms of crank walk and suffer the same problems. Any motor can.
It's always a possibility.
Well yea. But the chances of getting crankwalk/crankwalk symptoms are drastically lower in the 6 bolt blocks. He would have to have a massive puck clutch slamming onto the flywheel constantly to really even begin to see walk symptoms.
After rereading this, it is most likely that the clutch isn't disengaging from the flywheel which will slow the RPMs by means of friction.
^^^this is brilliant
I would check the master/slave cylinders, and vacuum lines actually to make sure nothing is leaking. Happened to my car a long time ago where the rpms would just drop and the car would die.
how does shifting feel when you drive the car?
