anubis
- 234
- 4
- Jul 23, 2003
Hemlock,
Michigan
i just finished my first turbo-charged dsm engine rebuild. had a lot of problems, but finally got it running. i took it for a test drive and i have a couple more problems now that i can't figure out. i am new to the turbo world of dsm, so i don't know much about turbo diagnostics. here's my trouble:
1) the car won't go over 2000rpm. it'll get there slowly, but then it bogs down and won't go any further. it's like that in every gear. i can get to 2000 in 1st, then shift and go to 2000 in 2nd and it bogs down. repeats all the way to 4th. i didn't bother with 5th.
2) no boost. the stock boost gauge is reading -7 (the very bottom of the gauge) and it's stuck there. when i start it, it goes to 0 and then once it's running, it's back to -7.
3) i think i'm running rich. there is moisture coming from a couple cracks in the manifold. it appears to be coming from the inside. too much fuel is the only thing that i can think that it could be right now.
the car is stock with a few exceptions: 2g pistons, p&p head, ffwd level 1 regrind cams, 3" downpipe (with cat eliminator) and a 3" muffler man cat-back with no muffler (this cat-back is temporary). i have an safcII wired up, but it's unplugged because i have not had time to set it up.
i don't know what the problem(s) is(are). i did search but couldn't find anything useful. i'm going to go check the intercooler pipes to make sure they're all hooked up nicely and try to get the safc tuned up. until then any help would be appreciated. thanks.
