Cant go 10 minutes without car over heating!! Wierd?! HELP
SikRacing97GST
308
Feb 17, 2004
Knoxville, Tennessee
LAst friday i installed my 3" turbo back exhaust and it was just last night i got off the interstate and noticed that my water temp was all the wayyy hott OMG so i pull over pop the hood, the resivoir for the coolent is full!!? and bubbling up, so i let it cool and let the cap vent the steam out and i wack the thermostat a couple of times and the coolent starts to drop and it seems to cool down, so im hoping this is just a stuck thermostat and not anything to do with my downpipe heating up the car????Help me guys i need to go to school tommorow !! :cry: :barf: :dsm:
your fans pluged in ? that could be it ? Im almost 100% sure that your Dp has nothing to do with it , just look around carfully and check for anything out of place good luck :thumb:
check your fan relays , they might have gone bad ? is the timp sensor pluged in ? just look around
also look to see it theres and wires , hoses , lines touching the DP that gets pretty damn hot .... :dsm:
I just got done changing the thermostat, everything seems to be cool as far as it ideling wise cant take it out on the road untill tommorow, i hope everything is a go it seems to be fine, thanks guys. By the way: make sure you buy the gasket or gasket maker :thumb: - Tony :dsm:
good luck man , were you runing it hard whenit was over heated ?> if so how long and also fo you have a front mount ? thanks
