Can't get my dash lights to turn off, even when key is out of ignition
ttuck
Nov 15, 2009
Cocoa Beach, Florida
Hi, I need help with trying to get my dash lights to turn off. My dash lights stay on all the time even if the key is out of the ignition, and for some reason my radio and gauges come on even after the turbo timer has gone off. they just turn back on
if i just turn the accessory key on the radio and gauges come on and go off like there supposed to when the key is taking out but when i turn it to on every stays on it really fustrating:banghead:
It's very weird, you will have to check every wire you have recently installed, it sounds like you have just installed the turbo timer and you have connected the key switch cable wrong.
Yea sounds like you got some wiring issues if you recently just install the timer, unplug the timer completely and see if that fixes it. GL
Yes the turbo timer was just installed recently ill try that and get back to you thank's
Does anyone know if i really need the turbo timer because if not im probably just gonna rip it out and just let the car idle before i tun it off
It's not really necesary, you will just have to leave the car ON after driving for like 2 or 4 minutes so the oil can lower it's temperature a bit, it will give your turbo and engine longer life.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
