Buying used transmission
dsmlivesmatter
51
10
Mar 31, 2019
hamburg, New York
Hey I was hoping to get some info from someone more knowledgeable than myself on this topic. I know of a awd 2g 5 speed transmission that is for sale with only 60k miles on it, apparantly the cars motor was blown in 2004 and it's just been sitting awaiting a new motor and the owner never got to it... anyways, is there anything I should look out for when I go to buy it? It's out of the car now
Check the oil, make sure it shifts, and if you could drop the pan and take a look at the valve body.
No valve body on a 5 speed...
If it's been sitting for that long my only worry is oil hasn't travelled through the gear set in a while, meaning whatever hasn't seen oil has the potential to rust. Aside from pulling it apart there's not a good way to tell, so checking the oil and making sure it engages and spins all gears. Make sure the t-case output spins as well.
Let's say there is surface rust on some of the internals, would you try to clean it up or just take it to a shop? I'm trying to save some money on my awd conversion I bought this car as a donor, previous owner had it disassembled and the shell sandblasted so it's completely stripped down
I'd clean it up myself, or at the very least inspect it myself. The current trans in my car is one I pulled apart, cleaned all the gunk off, inspected and reassembled. Granted everything looked very good in it and wasn't worn much, but it shifts amazing and has been flawless.
If you feel comfortable pulling it apart yourself then go that way, there is a vfaq on it HERE.
Good guide to follow, just take your time, be careful, CLEAN and ORGANIZED.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
