buildup help
Status
Not open for further replies.
importlegions
Oct 8, 2004
catawba, North Carolina
i have a n/a 4g63 6 bolt from a older talon in my garage and am wondering if i could use it for a build up and put it in a 97-98 eclipse gst when i get one. what possibilities are there for stroking the motor, or rebuilding it with stronger internals. i want to have a built bullet proof motor to drop in and keep the stock motor as a back up. also, if i use the 4g64 crank, do i have to bore out cylinder walls? thanks for the help, yes ima total newb to dsm's
i thnk ill go with the 2.3 liter stroker setup and use my 4g63 block, i found stroker kits thru searching this site there are 2 choices for the 4g63 6 bolt
opt.1 http://www.slowboyracing.com/more.php?id=2006&
opt.2 http://www.slowboyracing.com/more.php?id=2007&
is the second choice much better then the first? im pretty stoked i have a motor sitting outside i can actually use for the build. are the sleeves the same as the turbo one tho? and will i need to bore out my block at all? id like to put this all together but i norm. dont get stuff right the first time, so ill have someone else build it together for me, or is there a rebuild movie i can watch? i dont kno how difficult it would be so if its easy, ill do it ;)
Status
  • Wanted 6 bolt NT water pipe
    • chrisman287
