Broken half shaft and other assorted issues
nightfox939
Oct 20, 2011
Minneapolis, Minnesota
So the other night, I was driving down the highway, and BAM, all power gone, shaky wheel, the works. The last time I had a similar thing happen, the car threw a rod. Luckily, after towing it home, jacking it up and having a look, it looks as though the drivers side half shaft sheared right where it meets the hub of the wheel. Pic of what happened:
imgur: the simple image sharer
From there, I cleaned out all the shredded metal pieces that exploded down by the bearing, etc, and installed a new half shaft in there yesterday. Went without a hitch for the most part. Now to my concern: after putting in the half shaft, it drives... differently than it did before, it's hard to explain. The steering feels a little looser, and it generally doesn't feel as grippy and solid as it used to. There's also a concerning whirring type noise. My question mostly is: is there anything else that could have broken when the shaft broke, or something that broke that could have caused the shaft to break in the first place? Thanks for the input guys!
I can say for sure that there isn't any play on the left hand side; the side this happened on, because that was the first thing I checked for after fixing it and reassembling all of it before setting it down off the jack; I didn't check the right admittedly but I'll certainly check for that when I have another chance at it. Is there any possibility there's differential damage anywhere, because that's what I'm really concerned about at this point...
