brake line bracket and coilover
lotta hp
Banned Member
41
Sep 28, 2012
A, Georgia
This question is for the guys running megan racing coilovers
Do you guys have fitment issue with the brake line bracket not bolting onto the megan racing coilover?
The bracket does not fit so I have no where to secure it to. is this a common problem?
Yea I run the MR CO's, had them for over 4yrs now. I just used some zip ties. They were holding well then I replace the lines for SS lines. Using zip ties again with SS lines no problem.
If you can weld you could always move the bracket to where you need it. There usually just tack welded to the shock housing. So just hacksaw the bracket off, clean up the area you want to move it to and throw a small tack weld on to hold it. Just be sure to use proper setting on welder so you don't burn through on accident.
