2G Brake kit for 97 gsx
It depends on your needs. The double piston GSX brakes are really good if you have the right rotors and pads.
Powerstop is made by autospecialty. They're just powdercoated red.I got my 1g double piston calipers for $20 each on rock auto wholesaler closeout and painted them with black caliper paint LOL. The lines were like $3 each. I prefer OEM over SS when it comes to braking.
Rock only sells OEM replacements so your next level is either the outlander or evo upgrade. You can also spend a shitton on high end brake packages if you want.
Also make sure you shop around. Rock auto is probably the best price for calipers but you may luck out and find a deal like I did on rotors. I got Hawk powerslot rotors for $70/pr on amazon. Extreme PSI sells them for $150. Each.
