BOV recirc hose
eclipsegsx1736
Supporting VIP
1,599
44
Nov 11, 2003
Los Angeles, California
I bought my car vented, and hit fuel cut a few times at low boost in 1st, where can i get a recirculation hose for my Greddy Type-S? I need to know the diameter, length, material, etc and where can i get it? Home Depot? also besides just the hose what else do i need? my intake has a cap to accept the hose. thanks
:dsm:
Road Race engineering sells rubber hose up to 3". I believe home depot only goes to 1" or so. Check out the specialty plumbing stores in your area also, you'd be surprised
You live in santa monica, it's only about an hour drive if you want it badly :cool:
I only need the hose? I dont need some special fitting or soemthing to hook the hose to the intake?
...but that won't really help fuel cut
(if you didn't know) you will need a nipple on your intake pipe (the stock one has it) and a blowoff you can connect the hose to (stock has it) and then two worm rings to tighten around the hose. I took some measurements, made a crude picture and went to autozone :barf: and used a nice piece of radiator hose. It still gets good sound too because the hose is decently hard..... if you want some people choose to make theirs out of hard pipe because its a bit louder as well.
