Boost spike really bad, should I get 34mm flapper or go external gated
ok so i barrowed a hallman b/c from a friends and she still spikes.....i then just unplugged the wastegate(don't bi*** at me please) and it still goes to 20 then 15 in 2nd higher the gear hight it spikes to. why would this be? the turbo spins so freely that when i blew in the exhaust housing with my mouth is spun for a good 30 seconds it wasnt a really hard blow but a nice suttle one
If you have done a boost leak up to the pressure you are trying to run, the only thing I could think of is a bad waste gate actuator. I don't know if you have one you could swap in to test.
Seth
How do you have your MBC set up? It should go between the nipple on the j-pipe and the wastegate actuator- NOT from the blowoff valve line. Tapping into the blowoff valve line can cause a huge delay in opening the wastegate, which will lead to a boost spike.
I think the MBC is your issue. I tested one of those eBay boost controllers on my workbench once because I suspected it to be at fault on a customer's car. I used an air compressor to blow air into the inlet, while an air pressure gauge on the opposite end told exactly what pressure the MBC was limiting the pressure to. I absolutely could NOT get it to make a consistent number twice between 12 and 20psi. I'd set it to 20psi, back it out 1/8th turn and I'd be at 12. They're touchy, and I don't have the patience or time to mess with something that unreliable.
The only way boost can drop if there is not a boost leak is for the wastegate to open or maybe a remote chance the turbo is somehow bad. The only thing that I can think of is the flapper is somehow blowing open because the wastegate actuator isn't holding it closed. Why it would ever build any boost I don't know? Perhaps there is a threshold where the pressure in the exhaust manifold is sufficient to blow the flapper open.
You have already tried running without a boost source to the WGA. I would CAREFULLY go one step further and manually hold the flapper shut. If you can't make any boost then I have no idea WTF
Seth
My boost controller is also crazy. 1st 11psi, 2nd 13psi, 3rd 13psi, 4th 15psi, 5th 12psi Its a turbonetics one but it is on its way out the door i may just hook my 14b back up to the bcs untill i get a better boost controller.
