BOOST problems or not
eagetal96
39
Nov 7, 2004
grand forks, North Dakota
alright heres the deal, i have a 96 tsi. i have a boost guage and attemped to install a very shity boost controller. after realizing that it was a huge mistake i tryed to hook everything up to stock. i took some advice from what i thought was a reliable source but now im not so sure. the car was running 14.5 psi for a while, i was told that was correct, im not so sure about that. now i have uic/lip 1st gen bov and injen intake. after putting everything back together the car is running about 8 psi. so after putting to parts on the car it is about as fast as it was before, im a little disappointed but if thats how its suppost be be than i guess ill have to deal with it. if you have any thoughts on what is going on please give me your advice, thanks much
What do you have for boost control now? Just running a boost source straight to the WGA? You put on IC pipes so it may just be harder for the t2small to keep up the boost?
right now i dont even have a boost controller on it, but the way the lines are set up it is only running 8psi, is that even correct??? should it be higher or not, and i recently replaced all of the lines so that shouldnt be the prob.
  • Wanted 6 bolt NT water pipe
    • chrisman287
