boost leak testing?
tips000
277
Feb 22, 2011
kalkaska, Michigan
ok i have tested at the tb elbow and found/ fixed the leaks there and im still getting hard cold starts and high idle...
where is another easy access place to test... connecting directly to the turbo seems like its going to be a chore because the ic pipe is coming out the top of it... where should i test next?
i have the stock piping with an aftermarket bov... do i need to make another tester then?
The turbo is one of the best spots cause you test the whole turbo system, and are you getting a CEL for that cold start and high idle?
no and i have set the biss screw
