Boost Gauge
You T it to the p port on the throttle body or to the fuel pressure solenoid. http://vfaq.com/mods/wayback/BradBauer/gauges/fps.gif
The line you want to connect it to already has a plastic piece connecting it because it is two pieces. It is like the factory new that was going to be used as a boost source. Just take out that plastic piece and put in a plastic T.
I drilled and tapped mine right in the intake manifold on the elbow that comes out to your upper IC pipe. Just did it that way so I wouldn't have to deal with it while doing upgrades, also heard its more accurate but I don't really beleave that. Any of these will work
