boost gauge tap question for 2g
tsibribri
304
May 2, 2002
Pennsylvania
just got my 98 not long ago and noticed that there seems to be a spot tapped and a screw blocking it, and was wondering if this is for a boost guage or if its somthing else
thank you
That does appear to be the location that most people tap for a boost gauge (the line running from the fuel pressure solenoid to the intake manifold).
Yup, it looks like the old owner didn't have a fitting to put it there, so he put a screw in there. I would def attach a new fitting or replace that vac line. Don't want that screw popping out while driving.
Stay boostin
Even if the screw does pop out you probably will hardly notice. I was driving around and popped my boost gauge line off the T and the only thing I noticed other than a dead boost gauge was a better idle. It raised my idle up to around 800 instead of 700.
