Boost gauge.... read vfaq already
94TalonKid
80
Feb 22, 2003
New Jersey
I have been trying to hook this boost gauge up all day. I tried connecting it to the tubes near the driver side firewall like the vfaq says. I tried the 3 top tubes and the one on the bottom to the right. I finally gave up when none of the above worked. I finally hooked it up to the P elbow on the intake and it works but its slow and seems unaccurate. Any help would be appreciated.
- Dan
You're..... putting a boost gauge on an N/T?
Make sure you don't have any kinks in the line, use a line that won't collapse with vacuum, and hook it to a vac line going directly to the plenum, not on the throttle body.
Hmmm... guess it would help if i mentioned that I bought a 93 AWD TSI and that is the car that I am installing it on. Ill change my profile. Sorry about that.
Thanks.
Should it go into the tube that goes into the top of the Fuel Pressure Solenoid, or the bottom?
