boost controllers?
Status
Not open for further replies.
gstspyda97
148
Sep 30, 2004
Vandalia, Ohio
i searchd some threads but couldnt find exactly what i was looking for, im going to be getting a manual boost controller soon but i can figure out which one i want between
1.SBR MBC
2. Dejon Tool Dual Stage(the one for stock and you own boost setting)
i was wondering if any one has any experience with either of these and which one people would recommend for my setup see mod list in profile
also i want to buy 550s but i might upgrade to a big 16g after summer , so on my 14b im going to buy 550s or would it be better to get bigger injector since i might upgrade or would the 550s do me good on a b16g running around 20 psi
The Dejon ones i believe are good for 13 pounds of boost, after that you need to buy a wastegate feed to reduce boost spike. but you get the two settings and with a GST you can set it at low boost for takeoffs, then switch to high once tration gets better.
As for the SBR MBC i don't know about that, but i have heard a lot of good things about the Joe P, and now i belive you don't need a tool to change it. plus it is $10 cheaper at importevolution.
i found the Joe P for 40 bux on www.boostcontrollers.com so im just going to get that one since everyone has talked so good bout it :thumb: does any one have a good install guide for this on a 2g w/14b should i just do it from the BOV line then to the wastegate or does any one else have suggestions i have the stock compressor pipe on my 14b and it has the boost fitting should i put it from there to the wastegate for shorter hoses? :thumb: :thumb: also i plan on running 18-20 will teh joe p hold it pretty well and will i notice a lil quicker spool up time :thumb: :thumb:
Status
    • Sdcryan1
