bolt on intercoolers?
XxSiRhCy6PxX
179
Sep 26, 2004
san diego, California
Like what the title says. I just wanted to know if there was any cheap intercoolers that can just bolt in a 2g without any fabrications and customizations on the pipes? also, will it work will a david brode uicp? ive been searching for awhile and came to threads talking about pretty cheap intercoolers on ebay but it didnt really specify that it will bolt right in. :dsm:
Dejon Tool makes a street front mount for $550. It bolts directly up to the stock intercooler pipes. Its made out of two side mounts welded together. It hangs from the radiator bolts. May not look the greatest, but it will get the job done. Im not sure about this, but i read in a thread somewhere that someone bought it and it came with "Dejon" written across the front. You can contact them to find that out.
http://www.dejontool.com/DSM-2g FIC.htm
Hey, usually if your installing an intercooler more than likely they're all bolt on unless you have a factory one which might have a special kind of mounting harness or bracket (i dont know) but it should be easy. you might want to change the hoses anyway since new intercoolers have much better coolant flow. More than likely you can install an intercooler from an Eagle Talon since the car is pretty much identical with the exception of the model and make names... i wish i knew someone who was parting out their 95 Eclipse...2 engines would be nice
anyway i hope i shed some light on that for you..
peace,
-J-
--MastaYagi--
